USB Soldering Iron
$10.00
Only 3 left in stock (can be backordered)
SKU: USB_SOLDER_IRON_MINI Category:
This is a simple miniature soldering iron powered through a USB charging port. There’s a button for turning it on/off and a LED indicator to show on/off status.
Note 1: Do not try to unscrew the tip lid, it should be pulled straight out. Otherwise you may unscrew the solder tip and damage it.
Note 2: We’d recommend a higher quality soldering iron in most cases. But if you just need a simple one for soldering the DERULER electronics project this item will get the job done.
  • Power input: 5V 2A
  • USB soldering iron
  • USB power cable
  • Metal stand
  • Soldering tin 10g lead-free 0.6mm
