USB Isolator Module
$10.00
Only 4 left in stock
SKU: USB_ISOLATOR Category:
This USB Isolator Module prevents any ground current from flowing between the host port to the attached devices. Specifically this can be useful when using the KTH thermometer with a probe which is attached to a grounded metal surface and it’s powered through a USB port or when connecting it to the EVC2 for logging.
  • Isolation voltage max 1500V
  • Output power max 1W (5V 200mA)
  • USB transfer speed max 12 MBit/s (USB2.0 Full-speed)
