Power Limit Modifier (pack of 2)
$15.00
Only 7 left in stock (can be backordered)
SKU: PLM_PACK2 Category:
The Power Limit Modifier is designed to work as an adjustable shunt resistor for graphics card power limit modifications. It works by adjusting the gate voltage of a P-channel MOSFET which acts as a non-linear resistor. Simply solder the small circuit board in parallel with the existing shunt resistor. Then solder a wire from the square pad to the VR (variable resistor/potentiometer) and a second from the VR to ground. Adjusting the VR will then vary the gate voltage and in turn the equivalent resistance of the MOSFET.
  • Adjustable range 2.4 mΩ to infinite
  • Max current 20A @ Vgs = -2.5V, 25A @ Vgs = -10V
  • 2x Power Limit Modifier
  • 2x Variable Resistor 50 KΩ
  • 2x Black wire open ended 40 cm
  • 2x Black wire open ended to 1-pin 2.54 mm pitch 40 cm
Usage
EMF02P02H Datasheet
