K-type Thermocouple 1.5m/0.26mm (pack of 2)
$38.00
In stock (can be backordered)
SKU: TCK_15M_026MM_PACK2 Category:
Thin K-type thermocouple which is very flexible and easy to route to the measurement location. Usable for LN2 but typically reads around -170 *C in LN2 (can be recalibrated with the KTH thermometer). Each order item contains two probes.
  • Temperature range: -200 ℃ to 260℃ (measurement and material resistance)
  • Wire length: 1.5 m
  • Wire diameter: 0.6 x 0.9 mm
  • Tip diameter: 0.2 x 0.26 mm
