ElmorLabs Volcano X LN2 Container
$650.00
Out of stock
SKU: VOLCANO-X Category:
Get ready to shatter records and unleash the full potential of your CPU with the high-performing Volcano X LN2 pot, designed by ShaggySVK! This compact and lightweight pot is the ultimate tool for achieving extreme overclocking performance, using either liquid nitrogen or liquid helium to cool your CPU.
The mounting equipment is compatible with S1700, S20xx, AM4, AM5, LGA4677, TR4. It’s suggested to order the Volcano Mounting Kit if using this container with S1700 or AM4/5.
  • Liquid Nitrogen Container (Cu core, Alu tube/mount)
  • 4x Threaded rods M4 170mm
  • 4x Threaded rods M4 140mm
  • 4x Thumb screws M4
  • 4x Springs 1x7x25 mm
  • 8x Washers M4
  • 1x Isolation sheet 1000x100x10 mm
  • 1x Sandpaper 600 grit 280×230 mm
  • 1x Sandpaper 1000 grit 280×230 mm
