ElmorLabs UPP (USB Powered PCIe Adapter)
$20.00
In stock
SKU: UPP Category:
Discover the ElmorLabs UPP, a practical solution that provides an interface between your USB PD power supply and a device requiring a PCIe 6-pin connector for power such as the EFC-X9 or a graphics card. With the UPP, you can utilize a laptop charger or a USB PD power supply of 45W or higher as a power source. The recommended use case is with a USB PD 100W power supply which lets you meet the PCIe 6-pin specification of 75W. The UPP by ElmorLabs is a practical addition to your tech toolkit, providing alternative power connection options.
  • ElmorLabs UPP (USB Powered PCIe Adapter)
